[GRASS-user] grass-user Digest, Vol 105, Issue 36
Anna Petrášová
kratochanna at gmail.com
Tue Jan 20 18:28:54 PST 2015
You can do it easily yourself. Please follow the instructions on the bottom
of the page:
http://lists.osgeo.org/mailman/listinfo/grass-user
Thank you!
Anna
On Tue, Jan 20, 2015 at 4:54 PM, Maci Edwards <edwards.maci at gmail.com>
wrote:
> Please unsubscribe me. Thank you!
> On Tue, Jan 20, 2015 at 2:00 PM, <grass-user-request at lists.osgeo.org>
> wrote:
>> Send grass-user mailing list submissions to
>> grass-user at lists.osgeo.org
>> To subscribe or unsubscribe via the World Wide Web, visit
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> grass-user-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of grass-user digest..."
>> Today's Topics:
>> 1. GRASS/gdal grib2 decoding issue for new NCEP MRMS data
>> (Thomas Adams)
>> 2. Re: Large Grass Raster Notes (Markus Neteler)
>> 3. Re: Large Grass Raster Notes (Vaclav Petras)
>> Message: 1
>> Date: Mon, 19 Jan 2015 21:57:56 -0700
>> From: Thomas Adams <tea3rd at gmail.com>
>> To: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
>> Subject: [GRASS-user] GRASS/gdal grib2 decoding issue for new NCEP
>> MRMS data
>> Message-ID:
>> CAGxgkWjUL+LMHcV9EB013KGUAyhLnvcT2b-xMNGiSDw-GAHVFw at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> All:
>> I'm not on the gdal-dev at lists.osgeo.org mailing list, so I can not report
>> this here. NOAA/NCEP is producing new hourly CONUS NEXRAD radar-based
>> meteorological data -- my interest is precipitation. The data is available
>> now via a UCAR LDM process, described in the 1st link. The problem is
>> (using the downloadable sample data), gdal recognizes the data files as
>> grib2, but it will not decode the data (I have not previously had any
>> problems). The Google docs file states that there is an issue and points
>> to
>> an updated wgrib2 that can handle the grib2 decoding (which it does) --
>> the
>> second link.
>> wgrib2 v0.2.0.1 7/2014 Wesley Ebisuzaki, Reinoud Bokhorst, Jaakko Hyv?tti,
>> Dusan Jovic, Kristian Nilssen, Karl Pfeiffer, Pablo Romero, Manfred
>> Schwarb, Arlindo da Silva, Niklas Sondell, Sergey Varlamov
>> https://docs.google.com/document/d/1LeVcn_taIXZgzZb5JgWqaVr0xVs7GmA6RpHcb8ZGiwk/edit
>> http://www.cpc.noaa.gov/products/wesley/wgrib2/
>> When I used wgrib2 to produce a binary file, I could then import the
>> example data file into GRASS:
>> r.info map=MRMS_GaugeCorr_QPE_01H_00.00_20141208_120000 at teaiii
>> | Map: MRMS_GaugeCorr_QPE_01H_00.00_ Date: Mon Jan 19 20:36:05
>> 2015 |
>> | Mapset: teaiii Login of Creator:
>> teaiii |
>> | Location:
>> world_location |
>> | DataBase:
>> /home/teaiii/grass/data |
>> | Title: ( MRMS_GaugeCorr_QPE_01H_00.00_20141208-120000
>> | Timestamp:
>> none |
>> | Type of Map: raster Number of Categories:
>> 0 |
>> | Data Type:
>> FCELL |
>> | Rows:
>> 3500 |
>> | Columns:
>> 7000 |
>> | Total Cells:
>> 24500000 |
>> | Projection:
>> Latitude-Longitude |
>> | N: 55N S: 20N Res:
>> 0:00:36 |
>> | E: 60W W: 130W Res:
>> 0:00:36 |
>> | Range of data: min = 0 max =
>> 210.5 |
>> | Data
>> Description: |
>> | generated by
>> r.in.bin |
>> Comments: |
>> | r.in.bin -f
>> input="/home/teaiii/Downloads/MRMS_GRIB2_SAMPLE-precip/t\ |
>> | est.bin" output="MRMS_GaugeCorr_QPE_01H_00.00_20141208-120000"
>> bytes\ |
>> | =4 header=8 bands=1 order="native" north=55 south=20 east=-60
>> west=-\ |
>> | 130 rows=3500 cols=7000 anull=-3
>> flip="v" |
>> So, I thought the community would be interested in (1) knowing about the
>> data and (2) the GRASS/gdal decoding issue.
>> Cheers!
>> Tom
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <
>> http://lists.osgeo.org/pipermail/grass-user/attachments/20150119/2ce8984c/attachment-0001.html
>> Message: 2
>> Date: Tue, 20 Jan 2015 17:35:48 +0100
>> From: Markus Neteler <neteler at osgeo.org>
>> To: Jeshua Lacock <jeshua at 3dtopo.com>
>> Cc: GRASS user list <grass-user at lists.osgeo.org>
>> Subject: Re: [GRASS-user] Large Grass Raster Notes
>> Message-ID:
>> <CALFmHhuKm1=
>> xmcvDkOVa2vGZnwVC_ZAx7PLh7GxSqebBNVX8cA at mail.gmail.com>
>> Content-Type: text/plain; charset=UTF-8
>> On Sun, Jan 18, 2015 at 1:00 AM, Jeshua Lacock <jeshua at 3dtopo.com> wrote:
>> > Greetings,
>> > In the event my experience working with rather large GRASS rasters may
>> be useful, I thought I would share it. The following notes were compiled
>> running the GRASS 7.0.0beta4-141230 package on Mac OS X 10.10.1. The
>> system is a 6-core Xeon with 32GB of RAM, running in full 64-bit mode.
>> > 1. Using an r.external virtual mosaic as the input proved impossible
>> trying to run r.resample on it on trying to produce a nearly teracell
>> raster (I ended up breaking sub-tiles). I closely followed the instructions
>> on the Wiki.
>> > 2. On smaller sub-tiles of said image, r.resample was insanely slow
>> even with the external imagery.
>> You may check/benchmark the other resampling modules, some of them may
>> be more modern (ideally faster):
>> http://grass.osgeo.org/grass70/manuals/keywords.html#resample
>> In case you try, please share the outcome.
>> cheers,
>> Markus
>> Message: 3
>> Date: Tue, 20 Jan 2015 14:04:05 -0500
>> From: Vaclav Petras <wenzeslaus at gmail.com>
>> Message-ID:
>> CABo5uVsfKnMC3O+-g+kdK-yj4-29yhBLzvryTFeQrOL9VgPuaw at mail.gmail.com>
>> On Sun, Jan 18, 2015 at 1:03 PM, Jeshua Lacock <jeshua at 3dtopo.com> wrote:
>> > Actually, I misspoke, the wildcard will not work with long lists either
>> as
>> > it will crash with some kind argument too long message as well.
>> This is strange, the wild card is interpreted inside the module, so the
>> argument list shouldn't be too long. If you don't quite the pattern the
>> shell can do the expansion but this is not what you want.
>> Correct:
>> g.remove ... pattern="landsat_*"
>> Incorrect:
>> g.remove ... pattern=landsat_*
>> The later will transform the command line to:
>> g.remove ... pattern=landsat_01 landsat_02 landsat_03 landsat_04 ...
>> in case you are in directory with files or directories named landsat_01,
>> landsat_02, landsat_03, ...
>> What is the message you get? And what is the command return code (do echo
>> $? to find out)?
>> URL: <
>> http://lists.osgeo.org/pipermail/grass-user/attachments/20150120/6678f2d5/attachment-0001.html
>> End of grass-user Digest, Vol 105, Issue 36
> Desire can be of greater import than utility; experience more important
> than closure.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150120/573dba92/attachment-0001.html>
