[GRASS-user] r.massmov
Helmut Kudrnovsky
hellik at web.de
Fri Jan 23 11:47:02 PST 2015
Hi Maxi
>Danilo,
>could you tell us something more about your issue?
>- Are you using windows or linux?
>- Which GRASS version?
>Maxi
I've tested also for Danilo.
It's a winGRASS issue. Some tests a few days ago with trunk.
it seems r.massmov.exe is built ok in winGRASS.
(compilation log:
http://wingrass.fsv.cvut.cz/grass71/addons/grass-7.1.svn/logs/r.massmov.log)
unfortunately it shows no reaction if you call it from the winGRASS-windows
command line or from wxGUI-command line; thus the autogenerated GUI of
r.massmov doesn't come up:
> ScriptError
> Unable to fetch interface description for command
> 'r.massmov'.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-massmov-tp5181466p5183450.html
Sent from the Grass - Users mailing list archive at Nabble.com.
