[GRASS-user] r.massmov
Massimiliano Cannata massimiliano.cannata at supsi.ch
Sat Jan 24 05:31:55 PST 2015
It means that there's something to fix in the module?  Or is a grass issue?
Thanks
Maxi
Il giorno ven 23 gen 2015 20:47 Helmut Kudrnovsky <hellik at web.de> ha
scritto:
> Hi Maxi
> >Danilo,
> >could you tell us something more about your issue?
> >- Are you using windows or linux?
> >- Which GRASS version?
> >Maxi
> I've tested also for Danilo.
> It's a winGRASS issue. Some tests a few days ago with trunk.
> it seems r.massmov.exe is built ok in winGRASS.
> (compilation log:
> http://wingrass.fsv.cvut.cz/grass71/addons/grass-7.1.svn/
> logs/r.massmov.log)
> unfortunately it shows no reaction if you call it from the winGRASS-windows
> command line or from wxGUI-command line; thus the autogenerated GUI of
> r.massmov doesn't come up:
> > ScriptError
> > Unable to fetch interface description for command
> > 'r.massmov'.
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/r-massmov-tp5181466p5183450.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150124/848af067/attachment.html>
