[GRASS-user] grass 7.0 startup error
Gustavo Martínez gmpuljak at yahoo.com.ar
Mon Jan 26 12:08:46 PST 2015
I'm running a 64-bit Linux Mint 17.1 system. I've installed
grass70-core_7.0.0+1svn64321~ubuntu14.04.1_amd64.deb
from http://ppa.launchpad.net/grass/grass-devel/ubuntu/.
When I start grass70, after selecting the location and mapset I get the
following error:
Cleaning up temporary files...
Iniciando GRASS GIS...
(python:26247): Gtk-CRITICAL **: IA__gtk_widget_get_direction: assertion
'GTK_IS_WIDGET (widget)' failed
           __________  ___   __________    _______________
          / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
         / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
        / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
        \____/_/ |_/_/  |_/____/____/   \____/___//____/
Bienvenido a GRASS 7.0.0
Página de inicio de GRASS:               http://grass.osgeo.org
Esta versión corriendo a través de:      Bash Shell (/bin/bash)
Help is available with the command:      g.manual -i
Vea los términos de la licencia con:     g.version -c
Si lo necesita, reinicie la GUI con:     g.gui wxpython
En cuanto esté listo para quitar escriba:exit
Launching <wxpython> GUI in the background, please wait...
   File "/usr/bin/grass70", line 1461, in <module>
     bash_startup()
   File "/usr/bin/grass70", line 1122, in bash_startup
     _("3D raster MASK present")))
UnicodeEncodeError: 'ascii' codec can't encode character u'\xc1' in
position 180: ordinal not in range(128)
gustavo en neco:~$ ERROR: Variable 'LOCATION_NAME' not set
   File "/usr/lib/grass70/gui/wxpython/wxgui.py", line 37, in <module>
     from lmgr.frame import GMFrame
   File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 50, in <module>
     from lmgr.layertree        import LayerTree, LMIcons
   File "/usr/lib/grass70/gui/wxpython/lmgr/layertree.py", line 37, in
<module>
     from mapdisp.frame        import MapFrame
   File "/usr/lib/grass70/gui/wxpython/mapdisp/frame.py", line 65, in
<module>
     class MapFrame(SingleMapFrame):
   File "/usr/lib/grass70/gui/wxpython/mapdisp/frame.py", line 71, in
MapFrame
     page = None, Map = Map(), auimgr = None, name = 'MapWindow', **kwargs):
   File "/usr/lib/grass70/gui/wxpython/core/render.py", line 408, in
__init__
     self.mapfile = grass.tempfile(create = False) + '.ppm'
   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 704, in
tempfile
     return read_command("g.tempfile", flags=flags, pid=os.getpid()).strip()
   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 427, in
read_command
     return handle_errors(returncode, stdout, args, kwargs)
   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 310, in
handle_errors
     returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['g.tempfile', '-d',
'pid=26262'] ended with error
Process ended with non-zero return code 1. See errors in the (error) output.
After this message, grass closes and it returns to the console.
How can I fix it?
Many thanks,
Gustavo
Gustavo Martínez
Skype: gmpuljak
Linkedin: http://ar.linkedin.com/in/gustavomartínezpuljak
“Que la tierra se vaya haciendo camino ante tus pasos,
que el viento sople siempre a tus espaldas,
que el sol brille cálido sobre tu cara,
que la lluvia caiga suavemente sobre tus campos y,
hasta tanto volvamos a encontrarnos,
que Dios te lleve en la palma de su mano.”
