[GRASS-user] grass 7.0 startup error
Anna Petrášová
kratochanna at gmail.com
Tue Jan 27 08:26:33 PST 2015
On Mon, Jan 26, 2015 at 3:08 PM, Gustavo Martínez <gmpuljak at yahoo.com.ar>
wrote:
> Hi,
> I'm running a 64-bit Linux Mint 17.1 system. I've installed
> grass70-core_7.0.0+1svn64321~ubuntu14.04.1_amd64.deb
> from http://ppa.launchpad.net/grass/grass-devel/ubuntu/.
> When I start grass70, after selecting the location and mapset I get the
> following error:
I assume this is caused by some strings being newly translated into
Spanish, involving non ascii characters. There is a ticket for this
http://trac.osgeo.org/grass/ticket/2552, we are working on it.
Anna
> Cleaning up temporary files...
> Iniciando GRASS GIS...
> (python:26247): Gtk-CRITICAL **: IA__gtk_widget_get_direction: assertion
> 'GTK_IS_WIDGET (widget)' failed
> __________ ___ __________ _______________
> / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
> / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
> / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
> \____/_/ |_/_/ |_/____/____/ \____/___//____/
> Bienvenido a GRASS 7.0.0
> Página de inicio de GRASS: http://grass.osgeo.org
> Esta versión corriendo a través de: Bash Shell (/bin/bash)
> Help is available with the command: g.manual -i
> Vea los términos de la licencia con: g.version -c
> Si lo necesita, reinicie la GUI con: g.gui wxpython
> En cuanto esté listo para quitar escriba:exit
> Launching <wxpython> GUI in the background, please wait...
> Traceback (most recent call last):
> File "/usr/bin/grass70", line 1461, in <module>
> bash_startup()
> File "/usr/bin/grass70", line 1122, in bash_startup
> _("3D raster MASK present")))
> UnicodeEncodeError: 'ascii' codec can't encode character u'\xc1' in
> position 180: ordinal not in range(128)
> gustavo at neco:~$ ERROR: Variable 'LOCATION_NAME' not set
> File "/usr/lib/grass70/gui/wxpython/wxgui.py", line 37, in <module>
> from lmgr.frame import GMFrame
> File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 50, in <module>
> from lmgr.layertree import LayerTree, LMIcons
> File "/usr/lib/grass70/gui/wxpython/lmgr/layertree.py", line 37, in
> <module>
> from mapdisp.frame import MapFrame
> File "/usr/lib/grass70/gui/wxpython/mapdisp/frame.py", line 65, in
> <module>
> class MapFrame(SingleMapFrame):
> File "/usr/lib/grass70/gui/wxpython/mapdisp/frame.py", line 71, in
> MapFrame
> page = None, Map = Map(), auimgr = None, name = 'MapWindow', **kwargs):
> File "/usr/lib/grass70/gui/wxpython/core/render.py", line 408, in
> __init__
> self.mapfile = grass.tempfile(create = False) + '.ppm'
> File "/usr/lib/grass70/etc/python/grass/script/core.py", line 704, in
> tempfile
> return read_command("g.tempfile", flags=flags, pid=os.getpid()).strip()
> File "/usr/lib/grass70/etc/python/grass/script/core.py", line 427, in
> read_command
> return handle_errors(returncode, stdout, args, kwargs)
> File "/usr/lib/grass70/etc/python/grass/script/core.py", line 310, in
> handle_errors
> returncode=returncode)
> grass.exceptions.CalledModuleError: Module run None ['g.tempfile', '-d',
> 'pid=26262'] ended with error
> Process ended with non-zero return code 1. See errors in the (error)
> output.
> After this message, grass closes and it returns to the console.
> How can I fix it?
> Many thanks,
> Gustavo
> Gustavo Martínez
> Skype: gmpuljak
> Linkedin: http://ar.linkedin.com/in/gustavomartínezpuljak
> “Que la tierra se vaya haciendo camino ante tus pasos,
> que el viento sople siempre a tus espaldas,
> que el sol brille cálido sobre tu cara,
> que la lluvia caiga suavemente sobre tus campos y,
> hasta tanto volvamos a encontrarnos,
> que Dios te lleve en la palma de su mano.”
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150127/e88a3356/attachment-0001.html>
