[GRASS-user] Getting an error using r.mask in a GRASS shell script
Thomas Adams tea3rd at gmail.com
Tue Jan 27 13:01:04 PST 2015
Vaclav,
Fantastic; that did the trick! I figured the issue had to be something like
that, but I just had not been able to find it and, until now, this had not
been an issue.
Thank you very much…
Best regards,
Tom
On Tue, Jan 27, 2015 at 1:30 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Tue, Jan 27, 2015 at 3:04 PM, Thomas Adams <tea3rd at gmail.com> wrote:
>> Vaclav,
>> That was not a screen shot, just fg & bg colors of the text (I copied &
>> pasted from my Mac term window — sorry for the embellishments).
> I see it now. I was confused because it looks really bad at my end.
>> The errors I have been getting is this:
>> Traceback (most recent call last):
>>   File "/usr/local/grass-7.0.0beta3/scripts/r.mask", line 71, in <module>
>>     import grass.script as grass
>> ImportError: No module named grass.script
> "ImportError: No module named grass.script" means that Python does not
> see package (grass.script or also grass). You miss the PYTHONPATH variable
> which says where Python packages are:
> export PYTHONPATH="$GISBASE/etc/python:$PYTHONPATH"
> See the following in case you are missing some other variable which would
> be important for you (probably none now):
> http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly#Bash_examples_.28GNU.2FLinux.29
> If you would have a lot of problems with setting the environment, use
> GRASS_BATCH_JOB variable with the grass command (see grass70 --help).
> I hope this helps,
> Vaclav
> same result for RC1. My script is attached…
>> Tom
>> On Tue, Jan 27, 2015 at 12:57 PM, Vaclav Petras <wenzeslaus at gmail.com>
>> wrote:
>>> On Tue, Jan 27, 2015 at 12:00 PM, Thomas Adams <tea3rd at gmail.com> wrote:
>>>> Running as (1) is where I get the r.mask errors I have been seeing; I
>>>> get the errors both when I simply remove any existing MASKs (r.mask -r) or
>>>> where I attempt to set the MASK.
>>> Can you please post again what are the errors. It is not clear from the
>>> previous posts. Also, if you are posting script it is best to post a file,
>>> not a screenshot, or just copy and paste the script to the email if it is
>>> short enough.
>>> Thanks,
>>> Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150127/b630d2bd/attachment-0001.html>
