[GRASS-user] Convert landsat for pansharpening
Andrea Peri
aperi2007 at gmail.com
Wed Jul 1 16:30:50 PDT 2015
Hi Nikos,
I have success using your script to generate a very well pansharpen image.
Thx really much to You and Anna for help.
2015-07-01 15:42 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
> * Andrea Peri <aperi2007 at gmail.com> [2015-07-01 09:54:59 +0200]:
>> Hi,
>> Following the hint of Anna (use the python file) I have success to
>> start the script.
>> But I have some error.
>> More probably I insert wrong values.
>> Infact the script ask me the
>> "high resolution panchromatic image" . I insert the B8 from landsat8
>> that is the high resolution image.
>> after the script ask for the "Low resolution Multispectral images".
>> Here I need to insert the three images : B4,B3 and B2 of landsat8.
>> But I'm not sure how to insert them in a combo-list so I click three
>> time in this sequence: B4 B3 B2" and see they are added one after the
>> other.
> You can enter as many (multi-spectral) bands as you wish, separated by
> comma. For example:
> i.fusion.hpf pan=B8 msx=B4,B3,B2 --o -l center=mid modulation=max
> You can play with the parameters center and modulation.
> Nikos
> [rest deleted]
Andrea Peri
qwerty àèìòù
