[GRASS-user] Error exporting to tiff
Anna Petrášová
kratochanna at gmail.com
Wed Jul 1 17:24:01 PDT 2015
On Wed, Jul 1, 2015 at 8:11 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> I'm try-ing to export a tiff raster using this couple of commands:
> r.composite -c --overwrite red=refl4.hpf at PERMANENT
> green=refl3.hpf at PERMANENT blue=refl2.hpf at PERMANENT levels=256
> output=hpf
> r.out.gdal -c input=hpf at PERMANENT output=/path-to/hpf.tif
> format="GTiff" type="Byte"
> createopt="INTERLEAVE=PIXEL,TFW=YES,PROFILE=BASELINE,COMPRESS=DEFLATE"
> But I have an error:
> Checking GDAL data type and nodata value...
> 2..5..8..11..14..17..20..23..26..29..32..35..38..41..44..47..50..53..56..59..62..65..68..71..74..77..80..83..86..89..92..95..98..100
> WARNING: Selected GDAL datatype does not cover data range.
> WARNING: GDAL datatype: Byte, range: 0 - 255
> WARNING: Raster map <hpf at PERMANENT> range: 0 - 1.67114e+07
> WARNING: Raster export results in data loss.
> Using GDAL data type <Byte>
> Input raster map contains cells with NULL-value (no-data). The value
> 255 will be used to represent no-data values in the input map. You can
> specify a nodata value with the nodata option.
> ERROR: Raster export aborted.
> The message is absolutely not clear about what is the problem.
> I don't know if there some log where retrieve more information.
What is your region setting?
> Many thx for any help.
> Thx,
> Andrea Peri
> qwerty àèìòù
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150701/efebead7/attachment.html>
