[GRASS-user] Error exporting to tiff
Andrea Peri
aperi2007 at gmail.com
Wed Jul 1 23:42:09 PDT 2015
I create it from new retrieving the settings from the original geotiff I load.
Actually the region settings are this:
g.region -p
projection: 1 (UTM)
zone: 32
datum: wgs84
ellipsoid: wgs84
north: 5058915
south: 4825185
west: 587685
east: 817515
nsres: 30
ewres: 30
rows: 7791
cols: 7661
cells: 59686851
Thx,
2015-07-02 2:24 GMT+02:00 Anna Petrášová <kratochanna at gmail.com>:
> On Wed, Jul 1, 2015 at 8:11 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
>> Hi,
>> I'm try-ing to export a tiff raster using this couple of commands:
>> r.composite -c --overwrite red=refl4.hpf at PERMANENT
>> green=refl3.hpf at PERMANENT blue=refl2.hpf at PERMANENT levels=256
>> output=hpf
>> r.out.gdal -c input=hpf at PERMANENT output=/path-to/hpf.tif
>> format="GTiff" type="Byte"
>> createopt="INTERLEAVE=PIXEL,TFW=YES,PROFILE=BASELINE,COMPRESS=DEFLATE"
>> But I have an error:
>> Checking GDAL data type and nodata value...
>> 2..5..8..11..14..17..20..23..26..29..32..35..38..41..44..47..50..53..56..59..62..65..68..71..74..77..80..83..86..89..92..95..98..100
>> WARNING: Selected GDAL datatype does not cover data range.
>> WARNING: GDAL datatype: Byte, range: 0 - 255
>> WARNING: Raster map <hpf at PERMANENT> range: 0 - 1.67114e+07
>> WARNING: Raster export results in data loss.
>> Using GDAL data type <Byte>
>> Input raster map contains cells with NULL-value (no-data). The value
>> 255 will be used to represent no-data values in the input map. You can
>> specify a nodata value with the nodata option.
>> ERROR: Raster export aborted.
>> The message is absolutely not clear about what is the problem.
>> I don't know if there some log where retrieve more information.
> What is your region setting?
>> Many thx for any help.
>> Thx,
>> Andrea Peri
>> qwerty àèìòù
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Andrea Peri
qwerty àèìòù
