[GRASS-user] Error exporting to tiff
Andrea Peri
aperi2007 at gmail.com
Thu Jul 2 09:25:34 PDT 2015
Hi Nikos,
thx for hint,
I try the options Int16, UInt16, Int32 and UInt32,
but always the same error.
A.
2015-07-02 15:21 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
> * Andrea Peri <aperi2007 at gmail.com> [2015-07-02 09:26:31 +0200]:
>> Hi,
>> I resolve the error.
>> The original raster to convert was in 16bit value, and before to do
>> the r.gdal.out is need to rescale to 8 bit.
>> I wrongly uess the setting BYTE in r.gdal.out was to convert from 16bitto 8 bit.
>> Instead no, is necessary a convertion using rescale before.
> You should have other options (=formats) to export to so as to not
> sacrifice the radiometric resolution (16-bit).
> Did you try Int16 or UInt16?
> Nikos
Andrea Peri
qwerty àèìòù
