[GRASS-user] Exporting a raster tiff with RGB 3 bands produce a paletted tiff
Andrea Peri
aperi2007 at gmail.com
Fri Jul 3 05:06:58 PDT 2015
No, it was not what I expected .
I expected to see the same image I see in the grass display (using d.rgb)
Instead I see someone completelly different.
thx.
A.
2015-07-03 13:19 GMT+02:00 Moritz Lennert <mlennert at club.worldonline.be>:
> On 02/07/15 16:23, Andrea Peri wrote:
>> Hi Markus,
>> thx for hint.
>> I tried but probably I miss something.
>> because have an error:
>>> ERROR 6: SetColorTable() not supported for multi-sample TIFF
>>> files.
>>> ERROR 6: SetColorTable() can only be called on band 1.
>> I defined a group named "gruppo" and insert in it the three raster I
>> like to have for the three bands.
>> After I execute this command:
>> r.out.gdal -f --overwrite input=gruppo
>> output=D:\temp\hpf_out_rescale2.tif format=GTiff type=Byte
>> createopt=INTERLEAVE=PIXEL,TFW=YES,PROFILE=BASELINE,COMPRESS=DEFLATE
>> This is the results log:
>> r.out.gdal completo. File <D:\temp\hpf_out_rescale2.tif> created.
> And the created file is not what you wanted ?
> Moritz
Andrea Peri
qwerty àèìòù
