[GRASS-user] GRASS7 - Error (python:14221): Gtk-CRITICAL - Ubuntugis-unstable
Markus Neteler neteler at osgeo.org
Sat Jul 11 06:27:55 PDT 2015
On Sun, Jul 5, 2015 at 7:12 AM, Thayse Nery <thayse.nery at hotmail.com> wrote:
> Hi all,
> I installed GRASS 7 and QGis from the
> https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-unstable (Trusty
> 14.04) in Linux Mint 17.1 two weeks ago (sudo apt-get install postgis
> libgdal1h grass-dev grass-gui monteverdi2) and GRASS7 worked well for a week
> and now I have the following Error when I start the GRASS terminal:
> Starting GRASS GIS...
> (python:14221): Gtk-CRITICAL **: IA__gtk_widget_get_direction: assertion
> 'GTK_IS_WIDGET (widget)' failed
This is an unfortunately commonly seen message (also non-GRASS software).
Probably harmless. Do you observe any issues?
> I have uninstalled GRASS and installed again but I sill get the same error.
> How can I fix this error?
In Fedora they are gone - perhaps you need a newer GTK library version
(means: wait that Ubuntu updates it).
> Further, QGIS doesn't recognize GRASS7. Actually, I can see GRASS 7 on the
> QGis toolbox but it doesn't work.
> Is QGis prepared to support GRASS 7 through the QGIS/GRASS plugin?
To my knowledge work in progress... You can use GRASS GIS 7 in QGIS
via "processing" if you have a recent QGIS version installed.
> Is possible to have GRASS 6.4 installed in parallel to GRASS 7?
Yes.
> What would
> be the best way to have both GRASS 6.4 and GRASS 7.0 installed on Linux Mint
> 17.1 from repositories?
I suppose to simply install them but I am not familiar with Linux Mint
(others here?).
Another option is to compile the code locally, some guide is here:
http://grasswiki.osgeo.org/wiki/Compile_and_Install
Best
Markus
