[GRASS-user] Digitize in GRASS7.0
Roy
royroge at outlook.com
Tue Jul 21 05:52:01 PDT 2015
If you try to copy from background map a popup will open where you can
select the background layer;
maybe it was better to have the option to select the layer from the
right click menu as in 6.4.x
because now it will ask every time you use the tool (don't know if it is
a bug though)
Il 21/07/2015 12.15, Aldo Clerici ha scritto:
> I’m not able to find the “Use as Background Map” option in the
> contextual menu of vector layer, both in Windows and in Linux versions
> of Grass7.0. The option is available in 6.4.3 both for Windows and
> Linux. Is this a bug or a change not reported in Vector Digitizer manual ?
> Thanks
> A. Clerici
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150721/b60e7a16/attachment.html>
