[GRASS-user] R: Digitize in GRASS7.0
Aldo Clerici
aldo.clerici at unipr.it
Wed Jul 22 02:21:45 PDT 2015
Thanks Roy. Currently Im not able to evaluate what is the best procedure
but surely the manual page for GRASS7 should be updated for the new feature.
Da: grass-user-bounces at lists.osgeo.org
[mailto:grass-user-bounces at lists.osgeo.org] Per conto di Roy
Inviato: martedì 21 luglio 2015 14:52
A: grass-user at lists.osgeo.org
Oggetto: Re: [GRASS-user] Digitize in GRASS7.0
If you try to copy from background map a popup will open where you can
select the background layer;
maybe it was better to have the option to select the layer from the right
click menu as in 6.4.x
because now it will ask every time you use the tool (don't know if it is a
bug though)
Il 21/07/2015 12.15, Aldo Clerici ha scritto:
Im not able to find the Use as Background Map option in the contextual
menu of vector layer, both in Windows and in Linux versions of Grass7.0. The
option is available in 6.4.3 both for Windows and Linux. Is this a bug or a
change not reported in Vector Digitizer manual ?
Thanks
A. Clerici
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150722/d3754d1a/attachment.html>
