[GRASS-user] thematic map legend text not shown
Daniel Victoria
daniel.victoria at gmail.com
Wed Jul 22 03:23:07 PDT 2015
I've had some problems with legend text in grass gui. I fixed it by
setting the font explicitly (Arial for example). Not sure if it's your case
since I was using the gui to create the legend. But worth a try.
Cheers
Daniel
On Jul 16, 2015 4:22 AM, "henk witte" <henk.witte at groenholland.nl> wrote:
> Dear All,
> I am running GRASS 7.0
> I have been using GRASS GIS for a short time now but am impressed with the
> possibilities. However, I may have run into a problem. I have created a
> thematic map (d.vect.thematic) and saved the legend. I then use d.graph to
> display the legend. The class colors show up fine, but the accompanying
> text is not displayed. I have been playing around with d.graph, manually
> trying to draw text, but I cannot get any text to display.
> The legend file looks like:
> size 8 8
> symbol basic/box 25 5 10 black 255:255:204
> move 8 9
> text 0.000000 - 0.308333 | 133
> symbol basic/box 25 5 16 black 217:240:163
> move 8 15
> text 0.308333 - 0.616667 | 282
> symbol basic/box 25 5 22 black 173:221:142
> move 8 21
> text 0.616667 - 0.925000 | 114
> symbol basic/box 25 5 28 black 120:198:121
> move 8 27
> text 0.925000 - 1.233333 | 92
> symbol basic/box 25 5 34 black 49:163:84
> move 8 33
> text 1.233333 - 1.541667 | 0
> symbol basic/box 25 5 40 black 0:104:55
> move 8 39
> text 1.541667 - 1.850000 | 2
> I have also tried, for instance:
> color black
> size 20
> move 10 50
> text "ThequickbrownfoxThequickbrownfox"
> draw 100 10
> Here I try to draw some big text. I also draw a line (which displays
> fine), the idea being that the start of the line should change if I make
> the text longer. However, the line always starts at the same position.
> I hope someone knows a solution!
> Thanks,
> Henk Witte
> Groenholland Geo-energysystems
> Valschermkade 26
> 1059CD Amsterdam
> T: +31 (0)20 6159050
> M: +31 (0)628176535
> E: henk.witte at groenholland.nl
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150722/ac575ff8/attachment.html>
