[GRASS-user] How merge several raster float and monoband
Andrea Peri
aperi2007 at gmail.com
Mon Jul 27 01:27:01 PDT 2015
Thx Roy,
I will try it.
2015-07-27 10:10 GMT+02:00 Roy <royroge at outlook.com>:
> Hi Andrea,
> you may try " r.patch ".
> Il 26/07/2015 13.09, Andrea Peri ha scritto:
>> Hi,
>> I have several raster float64 and monoband partially overlapping to each
>> other.
>> My need is to merge each other to obtain 1 only larger raster.
>> Actually I do this using the gdal_merge utility, but in my global
>> process I will prefer to do this merge in the grass environment.
>> I know the r.composite command , but AFAIK it is only to compose a
>> raster RGB from three gray monoband raster and fully overlapping.
>> Thx.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Andrea Peri
qwerty àèìòù
