[GRASS-user] How merge several raster float and monoband
Roy
royroge at outlook.com
Mon Jul 27 01:10:20 PDT 2015
Hi Andrea,
you may try " r.patch ".
Il 26/07/2015 13.09, Andrea Peri ha scritto:
> Hi,
> I have several raster float64 and monoband partially overlapping to each other.
> My need is to merge each other to obtain 1 only larger raster.
> Actually I do this using the gdal_merge utility, but in my global
> process I will prefer to do this merge in the grass environment.
> I know the r.composite command , but AFAIK it is only to compose a
> raster RGB from three gray monoband raster and fully overlapping.
> Thx.
