[GRASS-user] Problems exporting Shapefiles
Luís Miguel Royo Pérez luis.miguel.royo at gmail.com
Mon Jul 27 04:27:14 PDT 2015
Hello everyone,
I have some problems exporting to shapefiles. When I try to export, I
get these errors:
This first shows when I try to export only naming a file... "output=
boundaries.shp"
/Check if OGR layer <ne_10m_populated_places_simple> contains polygons...//
//DBMI-SQLite driver error://
//Unable to open database: C:\Users\xxxxxxx\Documents\grass//
//data\nc_spm_08_grass7\PERMANENT\sqlite\sqlite.db//
//unable to open database file//
//WARNING: No ha sido posible abrir la base de datos
<C:\Users\xxxxxxx\Documents\grassdata\nc_spm_08_grass7\PERMANENT\sqlite\sqlite.db>
con el controlador <sqlite>.//
//ERROR: No se puede abrir la base de datos
<C:\Users\xxxxxx\Documents\grassdata\nc_spm_08_grass7\PERMANENT\sqlite\sqlite.db>
por el controlador <sqlite>//
This other one, shows when I indicate only a route:
"output=C:\Users\xxxxxxx\Documents\"
/ERROR 1: Failed to create directory
for shapefile datastore.
ERROR: No se puede abrir entrada de datos OGR
'C:\Users\LuísMiguel\Documents\'
/I'm using Windows 8.1, and GRASS 7.01RC2.
Anyone has any idea what's happening?
Thank you per advance!!
------------ pr?xima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150727/477509a5/attachment-0001.html>
