[GRASS-user] urgently help, please
Albert Saribekyan albertsaribekyan at rambler.ru
Mon Jul 27 06:27:45 PDT 2015
help me to understand this error:
I was input 12 tmin and 12 tmax maps to run r.bioclim module:
g.list rast
tmax10_17
tmax11_17
tmax12_17
tmax1_17
tmax2_17
tmax3_17
tmax4_17
tmax5_17
tmax6_17
tmax7_17
tmax8_17
tmax9_17
tmin10_17
tmin11_17
tmin12_17
tmin1_17
tmin2_17
tmin3_17
tmin4_17
tmin5_17
tmin6_17
tmin7_17
tmin8_17
tmin9_17
and run the module
r.bioclim
tmin=tmin1_17,tmin2_17,tmin3_17,tmin4_17,tmin5_17,tmin6_17,tmin7_17,tmin8_17,tmin9_17,tmin10_17,tmin11_17,tmin12_17
tmax=tmax1_17,tmax2_17,tmax3_17,tmax4_17,tmax5_17,tmax6_17,tmax7_17,tmax8_17,tmax9_17,tmax10_17,tmax11_17,tmax12_17
output=result
and there are following error
r.bioclim
output=result
Calculating monthly averages from min and max
BIO1 = Annual Mean Temperature ...
WARNING: Illegal filename <result.tavg12.1808
>. Character <
> not allowed.
ERROR: Raster map <result.tavg12.1808
> not found
File "C:\Users\Albert\AppData\Roaming\GRASS7\addons/script
s/r.bioclim.py", line 618, in <module>
main()
s/r.bioclim.py", line 169, in main
grass.run_command('r.series', input = tavg, output =
output, method = 'average')
File "C:\Program Files\GRASS GIS
7.0.0\etc\python\grass\script\core.py", line 375, in
run_command
return handle_errors(returncode, returncode, args,
kwargs)
7.0.0\etc\python\grass\script\core.py", line 310, in
handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None
['r.series', 'input=result.tavg01.1808,result.tavg02.1808,re
sult.tavg03.1808,result.tavg04.1808,result.tavg05.1808,resul
t.tavg06.1808,result.tavg07.1808,result.tavg08.1808,result.t
avg09.1808,result.tavg10.1808,result.tavg11.1808,result.tavg
12.1808\r', 'method=average', 'output=result.bio01.1808']
ended with error
Process ended with non-zero return code 1. See errors in the
(error) output.
(Mon Jul 27 17:18:15 2015) Command finished (41 sec)
please tell me where Im mistaken
Albert Saribekyan.
�������� � ������� HTML ���� ���������…
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150727/82191d3b/attachment.html>
