[GRASS-user] urgently help, please
Markus Neteler
neteler at osgeo.org
Mon Jul 27 07:22:32 PDT 2015
On Mon, Jul 27, 2015 at 3:27 PM, Albert Saribekyan
<albertsaribekyan at rambler.ru> wrote:
> help me to understand this error:
> I was input 12 tmin and 12 tmax maps to run r.bioclim module:
> g.list rast
> tmax10_17
> tmin9_17
> and run the module
> r.bioclim
> tmin=tmin1_17,tmin2_17,tmin3_17,tmin4_17,tmin5_17,tmin6_17,tmin7_17,tmin8_17,tmin9_17,tmin10_17,tmin11_17,tmin12_17
> tmax=tmax1_17,tmax2_17,tmax3_17,tmax4_17,tmax5_17,tmax6_17,tmax7_17,tmax8_17,tmax9_17,tmax10_17,tmax11_17,tmax12_17
> output=result
> and there are following error
> r.bioclim
> output=result
> Calculating monthly averages from min and max
> BIO1 = Annual Mean Temperature ...
> WARNING: Illegal filename <result.tavg12.1808
>>. Character <
>> not allowed.
> ERROR: Raster map <result.tavg12.1808
>> not found
For reasons which I don't understand Windows seems to have troubles
with the dot in the (temporary) file names used within the Python
script.
Any Windows user here who could try r.bioclim?
g.extension r.bioclim
r.bioclim ... (see above)
Maybe changing the dots to underscore in the script is sufficient to
get r.bioclim running on Windows, too.
thanks
Markus
PS: please use a reasonable subject line
