[GRASS-user] GRASS-7svn: Specify wxPython Version
Rich Shepard rshepard at appl-ecosys.com
Mon Jul 27 13:46:28 PDT 2015
On Mon, 27 Jul 2015, Glynn Clements wrote:
> The wxPython version is handled by the CheckForWx() function in
> gui/wxpython/core/globalvar.py. The default is taken from the
> GRASS_WXVERSION environment variable if that's defined, otherwise it
> allows wxversion to select the version, subject to the constraint that the
> version must be at least 2.8.10.1.
Glynn,
   I see that wxversion checks for a version >=2.8.10.1. As both 2.8.12.1 and
3.0.2.0 are installed I would expect CheckForWx() to find one or the other.
   Where should I define GRASS_WXVERSION so globalvar.py finds it?
~/.bash_profile was not checked.
Thanks,
Rich
