[GRASS-user] Query raster type
patrick s. patrick_gis at gmx.net
Tue Jul 28 04:39:03 PDT 2015
Hi Micha and Nikos
This was exactly what I was looking for! "Eval" seems a bit more
straightforward, as I do not need to query the string, but both
approaches seem to be valid.
Thanks a lot!
Patrick
/for i in `g.list type=rast`//
//do //
//    echo "adding layer '$i'" //
//    eval `r.info -g $i`//
//    if [ $datatype == "CELL" ] //
//    then//
//        v.db.addcolumn map=pt_grid column="$i integer"//
//    else//
//#    if ( $datatype == 'DCELL' ) //
//        v.db.addcolumn map=pt_grid column="$i double"//
//    fi//
//    v.what.rast map=pt_grid rast=$i col=$i//
//done;//
On 25.07.2015 19:47, Micha Silver wrote:
> On 07/25/2015 08:08 PM, patrick s. wrote:
>> Dear all
>> Is there a function in GRASS70 to match multiple rasters as values to
>> a point-vector. Some of the rasters are of type integer, some of type
>> float and the columns should ideally respect the datatype. It might
>> be possible as a bash.loop on v.what.rast, but I do not find a way to
>> query the datatype of a raster and get warnings:
> You can use r.info -g to get information about each rast, including
> datatype.
> So:
> eval `r.info -g $i`
> will put all raster parameters into shell variables, among them datatype.
> if ( $datatype == 'CELL' ) ...
>> for i in `g.list type=rast ` #ideally //only type integer OR float
>> //do //
>> //    v.db.addcolumn map=pt_grid column="$i double" #adapt datatype
>> of column according to raster type//
>> //done;
>> /Happy about any help and hint,
>> Patrick
>> This mail was received via Mail-SeCure System.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150728/8d24e92d/attachment.html>
