[GRASS-user] Query raster type
Nikos Alexandris
nik at nikosalexandris.net
Sat Jul 25 11:02:09 PDT 2015
* patrick s.:
> Dear all
> Is there a function in GRASS70 to match multiple rasters as values to a
> point-vector. Some of the rasters are of type integer, some of type
> float and the columns should ideally respect the datatype. It might be
> possible as a bash.loop on v.what.rast, but I do not find a way to query
> the datatype of a raster ...
You could get that info with
r.info RasterMapName -g |grep datatype
So I think it is possible to adapt the "datatype" below somehow.
Nikos
> ...and get warnings:
> for i in `g.list type=rast ` #ideally //only type integer OR float
> //do //
> // echo "adding layer '$i'" //
> // v.db.addcolumn map=pt_grid column="$i double" #adapt datatype of
> column according to raster type//
> // v.what.rast map=pt_grid rast=$i col=$i//
> //done;
