[GRASS-user] v.isochrones : error message
lcelati at cci-paris-idf.fr
Wed Jul 29 06:03:14 PDT 2015
Dear friends,
I 'm working with grass 7 on windows 7 32 bits. I loaded into grass OSM data
for driving isochrone. I selected only usefull roads : primary, secondary,
etc. And moreover, i create a max speed field thanks to the type of the
road.
I succed in loading start point and raod network OSm into grass.
But when i run the v.isochrones with r.cost method, grass crashes and the
following error message appears :
(Wed Jul 29 14:53:03 2015)
v.isochrones --overwrite map=bd_road_idf at data_set_isochronie_SSD
roads_layer=1 cost_column=speed_prof
start_points=Centroides_polarit_s_93_true at data_set_isochronie_SSD
isochrones=output_ROAD_isochrone time_steps=5 timemap=raster memory=1000
method=r.cost
Pass 1 of 48534:
Reading features...
Writing raster map...
File "C:\Users\lcelati\AppData\Roaming\GRASS7\addons/scrip
ts/v.isochrones.py", line 394, in <module>
main()
ts/v.isochrones.py", line 286, in main
memory=memory)
File "C:\Program Files\GRASS GIS
7.0.0\etc\python\grass\script\core.py", line 375, in
run_command
return handle_errors(returncode, returncode, args,
kwargs)
7.0.0\etc\python\grass\script\core.py", line 310, in
handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None
['v.to.rast', 'use=attr',
'input=bd_road_idf at data_set_isochronie_SSD', 'attrcolumn=1.0
/ (speed_prof * 1000 / 60)', 'memory=1000',
'output=cost_map_tmp_4332', 'type=line'] ended with error
Process ended with non-zero return code -1073741571. See
errors in the (error) output.
(Wed Jul 29 14:53:47 2015) La commande s'est terminée (43 sec)
What is the meaning of the message? I'm really surprised. Four months ago, i
tried to generate isochrones with the same method, same tool, same soft
without problem. And today, i am not abble to reproduce the process without
error message...
Could you help me?
Thanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-isochrones-error-message-tp5199989p5217552.html
Sent from the Grass - Users mailing list archive at Nabble.com.
