[GRASS-user] Query vector type has problems
Anna Petrášová
kratochanna at gmail.com
Fri Jul 31 05:56:47 PDT 2015
On Thu, Jul 30, 2015 at 12:06 PM, Andres Kuusk <andres at to.ee> wrote:
> Hello!
> Vector commands v.what.vect and v.distance do not fill the attribute
> column of a point vector.
> I created small test vectors, a vector map 'varea' of area type which has
> an area polygon, and a vector map of points 'vpoints' - 191 GPS way-points,
> 135 of which are inside the polygon.
> The command
> v.what.vect map=vpoints column=aid query_map=varea query_column=aid
> returns:
> Finding nearest features...
> Update vector attributes...
> 191 categories - no nearest feature found
I tried similar example, but it seems to work for me, perhaps you could
send us reproducible example which uses North Carolina sample datatset?
Thank you,
Anna
> The same result I get using v.distance:
> v.distance from=vpoints to=varea dmax=0. upload=to_attr column=aid
> to_column=aid
> If I omit the option 'dmax=0.' all points get the attribute 'aid', also
> the points outside the polygon.
> Both vectors have several columns in the table of attributes.
> The OS is OpenSUSE-13.1, 3.11.10-25-desktop, x86_64.
> The problem is there in:
> GRASS-7.0.0-2.42 from the repository
> http://download.opensuse.org/repositories/Application:/Geo/openSUSE_13.1
> GRASS-7.1 SVN r65785M
> (GRASS GIS 7.1.svn r65785M compilation log: No errors detected.)
> GRASS-7.0 SVN r58582.
> An old svn-version of 7.0 did the work (r51370):
> v.what.vect ...
> Finding nearest feature..
> Finding nearest areas...
> 2837 categories - no nearest feature found
> 23679 categories read from the map
> 23679 categories exist in the table
> 23679 categories read from the map exist in the table
> v.distance complete. 23679 records updated.
> 20842 points have got the attribute.
> Andres Kuusk
> Tartu Observatory, Estonia
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150731/3df56a67/attachment.html>
