[GRASS-user] i.atcorr for GeoEye-1 and Worldview-3
Nikos Alexandris
nik at nikosalexandris.net
Thu Jun 4 12:13:16 PDT 2015
* Markus Neteler <neteler at osgeo.org> [2015-06-04 20:52:54 +0200]:
> On Thu, Jun 4, 2015 at 2:19 PM, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
> >>> Do I understand correctly that you would need the numbers behind the
> >>> curves in this document:
> >>> https://www.digitalglobe.com/sites/default/files/DigitalGlobe_Spectral_Response_1.pdf
> Yes, exactly - we would need the original values which were used to produce:
> Figure 6. Spectral Response of the WorldView-3 panchromatic and
> multispectral imagery, visible and near infrared bands.
> > I don't have the time to do this now, but using something like [1], it
> > should be easy to quickly get an approximate dataset from the graphs in that
> > document.
> Maybe with a little more crowd-hunting or by someone just contacting
> DigitalGlobe we would get the table of values right away?
I tried to contact DigitalGlobe in the past about WV2. I did not
succeed back then. Maybe now if someone has recently bought some WV3
imagery.
Nikos
