[GRASS-user] i.atcorr for GeoEye-1 and Worldview-3
Nick Ves
vesnikos at gmail.com
Fri Jun 5 01:44:18 PDT 2015
Take note for WV3 [0] digital globe states that
WorldView-3 addresses this problem by being the first commercial imaging
satellite with an atmospheric sensor as part of its payload. During image
capture, the WorldView-3 atmospheric sensor is designed to detect the
presence of clouds, aerosols and water vapor at 31 meter resolution,
thereby measuring the exact atmospheric conditions corresponding to every
recorded image [...].
*DigitalGlobe has developed proprietary algorithms that use these
atmospheric measurements to normalize WorldView-3 imagery for consistency*.
This normalization is called atmospheric compensation, which is especially
important for information extraction, such as change detection and
vegetation analysis because changes
*due to the atmosphere have been removed*.
Which seems to imply that their (of-the-shelf) products are already
cleaned from any atmospheric artistic.
Further confirmation on that would I think is needed.
[0]
https://www.digitalglobe.com/sites/default/files/DG_Pixels_to_Products_forWeb.pdf
On Fri, Jun 5, 2015 at 10:43 AM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 04/06/15 21:13, Nikos Alexandris wrote:
>> * Markus Neteler <neteler at osgeo.org> [2015-06-04 20:52:54 +0200]:
>> On Thu, Jun 4, 2015 at 2:19 PM, Moritz Lennert
>>> <mlennert at club.worldonline.be> wrote:
>>>> Do I understand correctly that you would need the numbers behind the
>>>>>> curves in this document:
>>>>>> https://www.digitalglobe.com/sites/default/files/DigitalGlobe_Spectral_Response_1.pdf
>>> Yes, exactly - we would need the original values which were used to
>>> produce:
>>> Figure 6. Spectral Response of the WorldView-3 panchromatic and
>>> multispectral imagery, visible and near infrared bands.
>>> I don't have the time to do this now, but using something like [1], it
>>>> should be easy to quickly get an approximate dataset from the graphs in
>>>> that
>>>> document.
>>> Maybe with a little more crowd-hunting or by someone just contacting
>>> DigitalGlobe we would get the table of values right away?
>> I tried to contact DigitalGlobe in the past about WV2. I did not
>> succeed back then. Maybe now if someone has recently bought some WV3
>> imagery.
> Is this data confidential ? I would imagine that for DigitalGlobe it is an
> advantage if software can use their products, or ?
> Moritz
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150605/91f796ca/attachment.html>
