[GRASS-user] i.atcorr for GeoEye-1 and Worldview-3
Nikos Alexandris nik at nikosalexandris.net
Fri Jun 5 02:00:38 PDT 2015
* Nick Ves <vesnikos at gmail.com> [2015-06-05 11:44:18 +0300]:
> Take note for WV3 [0] digital globe states that
>  WorldView-3 addresses this problem by being the first commercial imaging
> satellite with an atmospheric sensor as part of its payload. During image
> capture, the WorldView-3 atmospheric sensor is designed to detect the
> presence of clouds, aerosols and water vapor at 31 meter resolution,
> thereby measuring the exact atmospheric conditions corresponding to every
> recorded image [...].
> *​​DigitalGlobe has developed proprietary algorithms that use these
> atmospheric measurements to normalize WorldView-3 imagery for consistency*.
> This normalization is called atmospheric compensation, which is especially
> important for information extraction, such as change detection and
> vegetation analysis because changes
> *​​due to the ​​atmosphere have been removed*.
> Which seems to imply that their (of-the-shelf) products are already
> cleaned​ from any atmospheric artistic.
> ​Further confirmation on that would I think is needed.​
> [0]
> https://www.digitalglobe.com/sites/default/files/DG_Pixels_to_Products_forWeb.pdf
Or, maybe it's simply still "new" and calibration wroks are still
on-going?
See:
<http://remotesensing.spiedigitallibrary.org/article.aspx?articleid=2300382>.
Nikos A
