[GRASS-user] Appending map to another with GRASS 7
simogeo simon.georget at gmail.com
Mon Jun 8 01:48:26 PDT 2015
Hi Markus,
Thanks for your reply. Actually,I investigated a bit more and I realized
that this is probably because of GRASS topological model.
As you can see, some of my generated polygons overlaps others - and some
centroids may be contained into others polygons (on same vector map). I
guess, GRASS doesn't like much this situation (could you confirm ?).
Anyway, any precision would be appreciated to understand better.
If you still think it could be a bug. I'll find time for reporting it.
Thanks again.
On Sun, Jun 7, 2015 at 10:38 PM, Markus Neteler [via OSGeo.org] <
ml-node+s1560n5209651h74 at n6.nabble.com> wrote:
> On Fri, Jun 5, 2015 at 9:22 AM, simogeo <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5209651&i=0>> wrote:
> > For information, it seems that creating not one but 3 layers make this
> work
> > correctly :
> > This sound like a bug, no ? I assume that because some polygons have
> same
> > centroid, GRASS get lost. Could it be the cause ?
> > Should I report it as bug or not ?
> While I am not sure if this a bug, please open a ticket for it along
> with an example (ideally for the North Carolina dataset). If related
> sample data need to be used in your example, you may export them with
> v.pack and attach to the ticket.
> Markus
> grass-user mailing list
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5209651&i=1>
> http://lists.osgeo.org/mailman/listinfo/grass-user
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Appending-map-to-another-with-GRASS-7-tp5209201p5209651.html
>  To unsubscribe from Appending map to another with GRASS 7, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5209201&code=c2ltb24uZ2VvcmdldEBnbWFpbC5jb218NTIwOTIwMXwzNzI5OTM0ODY=>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Appending-map-to-another-with-GRASS-7-tp5209201p5209706.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150608/fcb50f65/attachment.html>
