[GRASS-user] v.to.3d -r option not working properly
    Anna Petrášová
    kratochanna at gmail.com
    Tue Jun 16 19:33:16 PDT 2015
On Tue, Jun 16, 2015 at 9:42 AM, JanaKr <jkrajc at gmail.com> wrote:
> Hello,
> I imported a GMT multisegment ASCII file with contour lines using v.in.ogr,
> resulting in 3D vector file. Then I wanted to transform the z-coordinate to
> an attribute column using
> v.to.3d -r input=contour_3d col="CONC" output=contour_2d
> (I added CONC column to contour_3d before, using v.db.addcol map=contour_3d
> columns="CONC double precision").
> However, the resulting contour_2d column CONC remains empty. No error is
> reported.
> I am sure contour_3d contains correct Z-values (I transformed it to raster
> to see).
> Does anyone know what I am doing wrong, please?
nothing, it just was not implemented for lines, since 3D lines can have
vertices of different heights, but we can upload only one value. However,
since it makes perfectly sense for contours, I added the support for lines
there (r65493). Any chance you are using GRASS 7.1 (trunk) to try it out?
Anna
> http://osgeo-org.1560.x6.nabble.com/v-to-3d-r-option-not-working-properly-tp5211241.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150616/4775acc0/attachment.html>
