[GRASS-user] Error in pansharp tool: missing grass.script
    Vaclav Petras
    wenzeslaus at gmail.com
    Wed Jun 24 14:47:35 PDT 2015
On Wed, Jun 24, 2015 at 3:18 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> python --version =>2.7.3
> my system is a Debian 7 64bit.
> I remove the PYTHONPATH and try the changed as you suggest.
> but the error is still here.
> Traceback (most recent call last):
>   File "/usr/local/grass-7.0.0/scripts/i.pansharpen", line 91, in <module>
>     import grass.script as gscript
> ImportError: No module named grass.script
> The variable should not removed because otherwise is not founded the
> folders grass/script
> Meanwhile I notice the same issue "No module named grass.script" is
> also in i.colors.enhance
Please try also this commands:
python -c "import grass.script as grass"
python -c "import grass"
inside and outside of GRASS. This should find out if there is some other
package called grass.
Also find out Python version in and outside GRASS and run also
python -c "import sys; print(sys.path)"
It seems that PYTHONPATH=/usr/local/grass-7.0.0/etc/python is not set in
GRASS but it should be set automatically during the start, so something is
wrong.
Andrea.
> 2015-06-24 15:26 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> > On Wed, Jun 24, 2015 at 9:18 AM, Andrea Peri <aperi2007 at gmail.com>
> wrote:
> >> Hi Vaclav,
> >> thx for help.
> >> I have no problem to try your patch,
> >> If I understand , I should remove the
> >> env var PYTHONPATH and return to previous situation before try your
> patch
> > Yes and you should also try
> > python --version
> > and
> > from command line in GRASS.
> > What is your system?
> Andrea Peri
> qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150624/06d2c35e/attachment.html>
