[GRASS-user] Problem in running r.sim.water
vishal tiwari
hi.vishal123 at gmail.com
Thu Jun 25 04:24:53 PDT 2015
Looks like changing the projection system of the data seems to be working.
On 25 June 2015 at 13:33, vishal tiwari <hi.vishal123 at gmail.com> wrote:
> Dear Ma'am,
> Thank you for your response. Over the past couple of days I tried the
> r.sim.water over various number of data-sets and I was able to get the
> results for elevation data which have resolution of size greater than 10m.
> Although the results for very high resolution data-set were not getting
> generated even though the dimensions of the grid was not too big.
> So I created two kind of data-sets each having the following meta data:
> First (Not working) =>
> | Type of Map: raster Number of Categories:
> 255 |
> | Data Type:
> FCELL |
> | Rows:
> 49 |
> | Columns:
> 131 |
> | Total Cells:
> 6419 |
> | Projection: UTM (zone
> 13) |
> | N: 52.33036335 S: 52.32309305 Res:
> 0.00014837 |
> | E: 13.04243697 W: 13.03048443 Res:
> 0.00009124 |
> | Range of data: min = 43 max = 103
> Second (working) =>
> 255 |
> | Data Type:
> FCELL |
> | Rows:
> 53 |
> | Columns:
> 140 |
> | Total Cells:
> 7420 |
> 13) |
> | N: 52.33058068 S: -477.66941932 Res:
> 10 |
> | E: 1413.03011844 W: 13.03011844 Res:
> 10 |
> 103 |
> First (original) and second both are the same data-set. Second is
> generated by changing the resolution size to 10 (in degress, thus changing
> the S and E coordinates, which are wrong). But the original data-set have
> the pixel size of 10m X 10m (but shown in degrees).
> My question being does the format of the datasets projection have to be in
> a specific projection format for r.sim.water to work?
> Also can you please help me figure out how are the "Time step" value and
> "Number of iterations" in the simulation are being calculated, by pointing
> me to some references?
> Also apologies for the late relay.
> Thank you and kind regards,
> Vishal Tiwari
> On 13 June 2015 at 16:38, Markus Neteler <neteler at osgeo.org> wrote:
>> On Wed, Jun 10, 2015 at 11:21 AM, vishal tiwari <hi.vishal123 at gmail.com>
>> wrote:
>>> Hi all,
>>> I am trying to run the r.sim.water in GRASS. I have calculated the
>>> partial derivatives dx and dy rater map using r.slope.aspect. I am
>>> using this elevation map [1] to get the time-series depth map. But I think
>>> the output file is not being saved in the "outputDepth" rater map (says
>>> failed to open, on seeing the metadata).
>>> > r.sim.water -t elevin=testElevationLive at sampleMapSet
>>> dxin=dx at sampleMapSet dyin=dy at sampleMapSet rain_val=150 manin_val=0.015
>>> depth=outputDepth nwalk=50000 outiter=20
>>> STDOUT:
>>> Min elevation = 43.00 m
>>> Max elevation = 103.00 m
>>> Mean Source Rate (rainf. excess or sediment) = 0.000030 m/s or kg/m2s
>>> Mean flow velocity = 21.486384 m/s
>>> Mean Mannings = 0.015121
>>> Number of iterations = 647482826 cells
>>> Time step = 0.00 s
>>> and on the command console:
>>> Command 'd.rast map=outputDepth at sampleMapSet' failed
>>> Details: Raster map <outputDepth at sampleMapSet> not found
>>> [1] https://www.dropbox.com/s/ooxcj0y6v2kzeml/testElevationLive.tif?dl=0
>>> Thanks and Regards,
>> For the list archive record, the offlist answer by Helena Mitasova:
>> On Fri, Jun 12, 2015 at 10:52 PM, Helena Mitasova wrote:
>> > It is possible that there is no output - with time step smaller than
>> 0.001 it looks like you are running it at very high resolution
>> > on a huge DEM for some extreme storm event (150mm/hour - is that what
>> you are trying to model?)
>> > or you just don’t have your region set properly. To test, try to
>> increase the grid cell size and use 50mm/hr storm.
>> > Helena
>> Markus
> Vishal Tiwari
> Computer Science and Engineering
> Lab for Spatial Informatics
> IIIT-Hyderabad
Vishal Tiwari
IIIT-Hyderabad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150625/37e87ddc/attachment-0001.html>
