[GRASS-user] Error trying to compile grass 7 w/libLAS Debian Jessie
César Augusto Ramírez Franco caesarivs at gmail.com
Thu Jun 25 13:59:39 PDT 2015
On Thursday, June 25, 2015, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Thu, Jun 25, 2015 at 2:35 AM, César Augusto Ramírez Franco <
> caesarivs at gmail.com <javascript:_e(%7B%7D,'cvml','caesarivs at gmail.com');>>
> wrote:
>> 2015-06-25 1:09 GMT-05:00 César Augusto Ramírez Franco <
>>> ​The fact that I'm getting the same error on 7.0.0, 7.0.svn and 7.0.1RC1
>>> makes me think there must be something I'm doing wrong, or maybe the
>>> problem is in the liblas-bin and liblas-dev packages on debian ​repos.
>> ​Well, I just tried compiling libLAS from source:
>> wget http://download.osgeo.org/liblas/libLAS-1.8.0.tar.bz2
>> tar xjf libLAS-1.8.0.tar.bz2
>> mkdir libLAS-1.8.0/makefiles
>> cd libLAS-1.8.0/makefiles
>> cmake -G "Unix Makefiles" ../
>> make
>> make install
>> Tried ./configure ... --with-liblas=yes
>> And it worked
>> There must be something wrong with the packages on debian jessie repo
> In case you are sure, you had all the required packages installed before,
> you should report it to the maintainers. This should just work.
The package that has to be installed is liblas-c-dev, not liblas-dev. I
tried with that one and it compiled succesfully. Thanks!!!
*César Augusto Ramírez Franco*
Laboratorio de Sistemas Complejos Naturales
Escuela de Geociencias
Facultad de Ciencias
Universidad Nacional de Colombia - Sede Medellín
Teléfono: (57-4) 430 9369 - 300 459 6085
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150625/7333f47e/attachment.html>
