[GRASS-user] Error trying to compile grass 7 w/libLAS Debian Jessie
Vaclav Petras wenzeslaus at gmail.com
Thu Jun 25 07:13:33 PDT 2015
On Thu, Jun 25, 2015 at 2:35 AM, César Augusto Ramírez Franco <
caesarivs at gmail.com> wrote:
> 2015-06-25 1:09 GMT-05:00 César Augusto Ramírez Franco <
> caesarivs at gmail.com>:
>> ​The fact that I'm getting the same error on 7.0.0, 7.0.svn and 7.0.1RC1
>> makes me think there must be something I'm doing wrong, or maybe the
>> problem is in the liblas-bin and liblas-dev packages on debian ​repos.
> ​Well, I just tried compiling libLAS from source:
> wget http://download.osgeo.org/liblas/libLAS-1.8.0.tar.bz2
> tar xjf libLAS-1.8.0.tar.bz2
> mkdir libLAS-1.8.0/makefiles
> cd libLAS-1.8.0/makefiles
> cmake -G "Unix Makefiles" ../
> make
> make install
> Tried ./configure ... --with-liblas=yes
> And it worked
> There must be something wrong with the packages on debian jessie repo
In case you are sure, you had all the required packages installed before,
you should report it to the maintainers. This should just work.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150625/70a6750f/attachment-0001.html>
