[GRASS-user] Convert landsat for pansharpening
    Nikos Alexandris
    nik at nikosalexandris.net
    Mon Jun 29 15:58:29 PDT 2015
* Andrea Peri <aperi2007 at gmail.com> [2015-06-29 16:18:03 +0200]:
> Hi,
> I need to do a pansharpen of a landsat image.
Andrea, can you get and compile the following tool?
<https://github.com/NikosAlexandris/i.fusion.hpf>
I might suit your need well.
Nikos
> But I see the landsat is an integer (16bit) image meanwhile the
> pansharpen is a
> pixel procedure (RGB = 0-255,0-255,0-255)
> So I guess is need to convert to an byte image.
> I try to do this using the
> r.rescale tool with to=0,255
> but I'm not sure to use the right tool.
> Many thx.
