[GRASS-user] Convert landsat for pansharpening
Andrea Peri
aperi2007 at gmail.com
Tue Jun 30 00:24:08 PDT 2015
Hi Nikos
really interesting.
Is it capable to work with the landscape images as input (16bit x
channel images) ?
thx for help.
A.
2015-06-30 0:58 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
> * Andrea Peri <aperi2007 at gmail.com> [2015-06-29 16:18:03 +0200]:
>> Hi,
>> I need to do a pansharpen of a landsat image.
> Andrea, can you get and compile the following tool?
> <https://github.com/NikosAlexandris/i.fusion.hpf>
> I might suit your need well.
> Nikos
>> But I see the landsat is an integer (16bit) image meanwhile the
>> pansharpen is a
>> pixel procedure (RGB = 0-255,0-255,0-255)
>> So I guess is need to convert to an byte image.
>> I try to do this using the
>> r.rescale tool with to=0,255
>> but I'm not sure to use the right tool.
>> Many thx.
Andrea Peri
qwerty àèìòù
