[GRASS-user] Convert landsat for pansharpening
Andrea Peri
aperi2007 at gmail.com
Tue Jun 30 01:12:06 PDT 2015
Hi Nikos,
unfortunately,
I'm not able to compile it on windows.
My windows Grass installation come from osgeo4w.
and is not vailable the compile environment.
I could compile it on my server linux, but in that environment I have
not the GUI interface to test the results.
Thx however.
A.
2015-06-30 9:24 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi Nikos
> really interesting.
> Is it capable to work with the landscape images as input (16bit x
> channel images) ?
> thx for help.
> A.
> 2015-06-30 0:58 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
>> * Andrea Peri <aperi2007 at gmail.com> [2015-06-29 16:18:03 +0200]:
>>> Hi,
>>> I need to do a pansharpen of a landsat image.
>> Andrea, can you get and compile the following tool?
>> <https://github.com/NikosAlexandris/i.fusion.hpf>
>> I might suit your need well.
>> Nikos
>>> But I see the landsat is an integer (16bit) image meanwhile the
>>> pansharpen is a
>>> pixel procedure (RGB = 0-255,0-255,0-255)
>>> So I guess is need to convert to an byte image.
>>> I try to do this using the
>>> r.rescale tool with to=0,255
>>> but I'm not sure to use the right tool.
>>> Many thx.
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
