[GRASS-user] can't compile gdal-grass plugin against grass7
    Donovan Cameron
    sault.don at gmail.com
    Tue Mar 10 15:06:42 PDT 2015
Afternoon everyone,
I'm having some problems getting the gdal-grass 1.11.2 plugin to compile
with grass 7.0.0 installed on Arch Linux 64bit.
I've compiled GDAL 1.11.2 --without-grass, then compiled grass 7.0.0
from the tar archive.
Next tried to compile gdal-grass plugin but it complains:
configure: error: --with-grass=/opt/grass requested, but libraries not
found!  Perhaps you need to set LD_LIBRARY_PATH to include /opt/grass/lib?
GRASS installed a grass.conf into /etc/ld.so.conf.d/ with the contents
/opt/grass/lib and then I ran "sudo ldconfig" but still get same error.
The config.log for gdal-grass has a part in it that says:
"/usr/bin/ld: cannot find -lgrass_gis.7.0.svn
/usr/bin/ld: cannot find -lgrass_raster.7.0.svn
/usr/bin/ld: cannot find -lgrass_gmath.7.0.svn
/usr/bin/ld: cannot find -lgrass_datetime.7.0.svn
/usr/bin/ld: cannot find -lgrass_gproj.7.0.svn
/usr/bin/ld: cannot find -lgrass_vector.7.0.svn
/usr/bin/ld: cannot find -lgrass_dbmibase.7.0.svn
/usr/bin/ld: cannot find -lgrass_dbmiclient.7.0.svn
/usr/bin/ld: cannot find -lgrass_dgl.7.0.svn
/usr/bin/ld: cannot find -lgrass_dig2.7.0.svn
/usr/bin/ld: cannot find -lgrass_rtree.7.0.svn
/usr/bin/ld: cannot find -lgrass_linkm.7.0.svn
/usr/bin/ld: cannot find -lgrass_btree2.7.0.svn
/usr/bin/ld: cannot find -lgrass_ccmath.7.0.svn"
But /opt/grass/lib has files with a full version number like
libgrass_gis.7.0.0.so instead of libgrass_gis.7.0.svn.so
And those are symlinks like "libgrass_gis.7.0.0.so -> libgrass_gis.so"
Any help would be greatly appreciated or if anyone needs more info, feel
free to ask.
Donovan
