[GRASS-user] can't compile gdal-grass plugin against grass7
Donovan Cameron
sault.don at gmail.com
Tue Mar 10 16:26:30 PDT 2015
Looks like gdal-grass is a GDAL product so I'll forward this issue to
the GDAL mailing lists.
Sorry for the noise =)
Donovan
On 10/03/15 03:06 PM, Donovan Cameron wrote:
> Afternoon everyone,
> I'm having some problems getting the gdal-grass 1.11.2 plugin to
> compile with grass 7.0.0 installed on Arch Linux 64bit.
> I've compiled GDAL 1.11.2 --without-grass, then compiled grass 7.0.0
> from the tar archive.
> Next tried to compile gdal-grass plugin but it complains:
> configure: error: --with-grass=/opt/grass requested, but libraries not
> found! Perhaps you need to set LD_LIBRARY_PATH to include
> /opt/grass/lib?
> GRASS installed a grass.conf into /etc/ld.so.conf.d/ with the contents
> /opt/grass/lib and then I ran "sudo ldconfig" but still get same error.
> The config.log for gdal-grass has a part in it that says:
> "/usr/bin/ld: cannot find -lgrass_gis.7.0.svn
> /usr/bin/ld: cannot find -lgrass_raster.7.0.svn
> /usr/bin/ld: cannot find -lgrass_gmath.7.0.svn
> /usr/bin/ld: cannot find -lgrass_datetime.7.0.svn
> /usr/bin/ld: cannot find -lgrass_gproj.7.0.svn
> /usr/bin/ld: cannot find -lgrass_vector.7.0.svn
> /usr/bin/ld: cannot find -lgrass_dbmibase.7.0.svn
> /usr/bin/ld: cannot find -lgrass_dbmiclient.7.0.svn
> /usr/bin/ld: cannot find -lgrass_dgl.7.0.svn
> /usr/bin/ld: cannot find -lgrass_dig2.7.0.svn
> /usr/bin/ld: cannot find -lgrass_rtree.7.0.svn
> /usr/bin/ld: cannot find -lgrass_linkm.7.0.svn
> /usr/bin/ld: cannot find -lgrass_btree2.7.0.svn
> /usr/bin/ld: cannot find -lgrass_ccmath.7.0.svn"
> But /opt/grass/lib has files with a full version number like
> libgrass_gis.7.0.0.so instead of libgrass_gis.7.0.svn.so
> And those are symlinks like "libgrass_gis.7.0.0.so -> libgrass_gis.so"
> Any help would be greatly appreciated or if anyone needs more info,
> feel free to ask.
> Donovan
