[GRASS-user] d.vect: How to achieve transparency ?
Glynn Clements
glynn at gclements.plus.com
Sat Mar 14 04:08:44 PDT 2015
"Peter Löwe" wrote:
> is there a known way to render a vector layer on a GRASS monitor
> (from the GRASS Shell, not through a GUI) with a level of
> transparency, except for r.composite-based workarounds? Any solution
> for either GRASS7.x or GRASS6.x would be welcomed.
The display API doesn't support blending.
The GUI implements layer transparency by rendering each layer to a
separate image then specifying the opacity for each layer when the
images for the individual layers are composited using g.pnmcomp.
