[GRASS-user] Copy raster map from one unprojected location to another
Nikos Alexandris
nik at nikosalexandris.net
Thu Mar 19 04:44:52 PDT 2015
Johannes Radinger wrote:
> Doesn't work either with the -o flag:
> r.unpack --o
> input=/media/grassgis_data/tmp/tmp_Cele_raster_pack/my_raster.pack
> output=my_raster
> Traceback (most recent call last):
> File "/usr/local/grass-7.0.1svn/scripts/r.unpack", line 146, in
> <module>
> sys.exit(main())
> File "/usr/local/grass-7.0.1svn/scripts/r.unpack", line 104, in
> main
> proj=True):
Lines 115, 116 in r.unpack.py look a bit strange:
115 if flags['o']:
116 grass.warning(_("Projection information does not match.
Proceeding..."))
I mean, if the "-o" flag is instructed, which for line 115, means
"True",
then issue the warning message.
The message seems to contradict the intention of using the flag here?
Maybe I don't get it right though.
Nikos
> File "/usr/local/grass-7.0.1svn/etc/python/grass/script/core.py",
> line
> 863, in compare_key_value_text_files
> checkunits=units)
> line
> 790, in _text_to_key_value_dict
> text = open(filename, "r").readlines()
> IOError: [Errno 2] No such file or directory: 'PROJ_INFO'
