[GRASS-user] Copy raster map from one unprojected location to another
Nikos Alexandris
nik at nikosalexandris.net
Thu Mar 19 05:03:34 PDT 2015
Johannes Radinger wrote:
>> Doesn't work either with the -o flag:
>> r.unpack --o
>> input=/media/grassgis_data/tmp/tmp_Cele_raster_pack/my_raster.pack
>> output=my_raster
>> Traceback (most recent call last):
>> File "/usr/local/grass-7.0.1svn/scripts/r.unpack", line 146, in
>> <module>
>> sys.exit(main())
>> File "/usr/local/grass-7.0.1svn/scripts/r.unpack", line 104, in
>> main
>> proj=True):
Nikos Alexandris wrote:
> Lines 115, 116 in r.unpack.py look a bit strange:
> 115 if flags['o']:
> 116 grass.warning(_("Projection information does not match.
> Proceeding..."))
> I mean, if the "-o" flag is instructed, which for line 115, means
> "True",
> then issue the warning message.
> The message seems to contradict the intention of using the flag here?
> Maybe I don't get it right though.
So, why go into checking anything regarding PROJ_INFO or PROJ_UNITS if
the "-o" flag is instructed?
Completely untested, but maybe the script needs a modification (?), as
follows:
if flags['o']:
grass.warning(_("Overriding projection check (using current
location's projection)!"))
else:
diff_result_1 = diff_result_2 = None
proj_info_file_1 = 'PROJ_INFO'
proj_info_file_2 = os.path.join(mset_dir, '..', 'PERMANENT',
'PROJ_INFO')
if not
grass.compare_key_value_text_files(filename_a=proj_info_file_1,
filename_b=proj_info_file_2,
proj=True):
diff_result_1 = diff_files(proj_info_file_1,
proj_info_file_2)
proj_units_file_1 = 'PROJ_UNITS'
proj_units_file_2 = os.path.join(mset_dir, '..', 'PERMANENT',
'PROJ_UNITS')
if not
grass.compare_key_value_text_files(filename_a=proj_units_file_1,
filename_b=proj_units_file_2,
units=True):
diff_result_2 = diff_files(proj_units_file_1,
proj_units_file_2)
if diff_result_1 or diff_result_2:
if diff_result_1:
grass.warning(_("Difference between PROJ_INFO file of
packed map "
"and of current
location:\n{diff}").format(diff=''.join(diff_result_1)))
if diff_result_2:
grass.warning(_("Difference between PROJ_UNITS file of
packed map "
"and of current
location:\n{diff}").format(diff=''.join(diff_result_2)))
grass.fatal(_("Projection information does not match.
Aborting."))
Nikos
