[GRASS-user] GRASS crashes while running i.atcorr
Nikos Alexandris
nik at nikosalexandris.net
Sat May 2 00:21:06 PDT 2015
* Jake Chila <jake.chila at gmail.com> [2015-05-01 11:33:01 -0300]:
> hi all,
> So I am trying to run i.atcorr but every time I run it, the whole program
> goes unresponsive and crashes. Has anyone experienced this before? Is there
> any way I can fix it?
> One thing that might be causing it is my parameters text file. I'm not
> totally sure I understand what all the fields are but here is an example of
> the parameter files I have created. This one is for the second band of a
> landsat 5 TM scene over central British Columbia
> 7
> 8 15 18.49 -116.027755 50.267045
> 2
> 0
> 0
> 0
> -1000
> 26
Hi Jake.
Please have a close look in the manual. As well, here:
<http://grasswiki.osgeo.org/wiki/Atmospheric_correction#Atmospheric_correction>.
If Landsat is your sensor to work with, here is a script around
i.atcorr: <https://github.com/NikosAlexandris/i.landsat.atcorr>. I
haven't used this in Windows though, and to upload it into grass-addons
I need to test it more.
Hope this helps a bit,
Nikos
> I understand most of the parameters except the aerosol model, mean target
> elevation and sensor height. Are these in the metadata file? I don't know
> about the aerosol module, but for the elevation, doesn't this come from the
> DEM attached? Lastly, I went with -1000 for sensor height because the grass
> wiki page says -1000 sensor height (here, sensor on board a satellite) so I
> assumed this was a preset value.
> Once again, I don't know if the parameter file is the issue, or the only
> issue at least, so any advice running i.atcorr would be much appreciated!
> Thanks,
> JDC
