[GRASS-user] GRASS crashes while running i.atcorr
Nikos Alexandris
nik at nikosalexandris.net
Sat May 2 01:38:23 PDT 2015
* Nikos Alexandris <nik at nikosalexandris.net> [2015-05-02 10:21:06 +0300]:
> * Jake Chila <jake.chila at gmail.com> [2015-05-01 11:33:01 -0300]:
> > hi all,
> > So I am trying to run i.atcorr but every time I run it, the whole program
> > goes unresponsive and crashes. Has anyone experienced this before? Is there
> > any way I can fix it?
> > One thing that might be causing it is my parameters text file. I'm not
> > totally sure I understand what all the fields are but here is an example of
> > the parameter files I have created. This one is for the second band of a
> > landsat 5 TM scene over central British Columbia
> > 7
> > 8 15 18.49 -116.027755 50.267045
> > 2
> > 0
> > 0
> > 0
> > -1000
> > 26
> Hi Jake.
> Please have a close look in the manual. As well, here:
> <http://grasswiki.osgeo.org/wiki/Atmospheric_correction#Atmospheric_correction>.
> If Landsat is your sensor to work with, here is a script around
> i.atcorr: <https://github.com/NikosAlexandris/i.landsat.atcorr>. I
> haven't used this in Windows though, and to upload it into grass-addons
> I need to test it more.
Unfortunately, something is broken currently and I have no time to check
it :-(.
Nikos
