[GRASS-user] grass program compilation
alassane toure
atourej at gmail.com
Mon May 4 19:23:39 PDT 2015
Group,
I need your help to start developing new functions based on existing
ones and GRASS libraries. My short term goal is to be able to compile
the test program r.example.
I first started by installing the binary using the followings on Ubuntu:
(1)
sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
sudo add-apt-repository ppa:grass/grass-stable
sudo apt-get update
sudo apt-get install grass7
(2) Because I needed the libraries, I downloaded grass-7.0.0.tar.gz
and followed instructions provided in
"http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu"
However when I issued the command...
sudo make install
The system response was...
alassane at alassane-MS-7593:~/Downloads$ sudo make install
[sudo] password for alassane:
make: *** No rule to make target `install'. Stop.
Any help to compile r.example is appreciate.
Regards,
Alassane
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150504/1c60aa73/attachment.html>
