[GRASS-user] grass program compilation
Vaclav Petras
wenzeslaus at gmail.com
Wed May 6 08:59:32 PDT 2015
On Wed, May 6, 2015 at 11:53 AM, alassane toure <atourej at gmail.com> wrote:
> Group,
> I am still not making any progress compiling Grass70 on Ubuntu. Here is
where i am at:
> 1. able to run configure without any problem (with your help);
> 2. unable to compile using the following commands:
> make -j2 && sudo make install && sudo ldconfig
> And the system response was ....
> include/Make/Vars.make:1: include/Make/Platform.make: No such file or
directory
> make: *** No rule to make target `include/Make/Platform.make'. Stop.
What was the output of configure? Perhaps it fails. Make cannot find a
makefile which should be generated by configure.
Note that for running make, you need to be in the directory with the source
code (as needed for configure).
> Your help is appreciated.
> Alassane
> On Tue, May 5, 2015 at 2:13 PM, alassane toure <atourej at gmail.com> wrote:
>> Great! ./configure worked! However compilation and installation did
not.
>> I run the following command:
>> and the system response was:
directory
>> I appreciate your comments/suggestions.
>> Alassane
>> On Tue, May 5, 2015 at 2:03 PM, Markus Neteler <neteler at osgeo.org> wrote:
>>> On Tue, May 5, 2015 at 9:59 PM, alassane toure <atourej at gmail.com>
>>> great!
>>> > However compilation and installation did not.
>>> > directory
>>> please send it to the list, I am on Fedora...
>>> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150506/2d6176bd/attachment.html>
