[GRASS-user] i.landsat.toar and zero values in GRASS 7.0.0
Katerina-Karolina Karapanou kk_karapanou at hotmail.com
Fri May 8 08:48:27 PDT 2015
I have a Landsat TM image (2007) and I work in GRASS 7.0.0. in Windows 7.
                                      Once again, trying to apply the module i.landsat.toar in the right way, via GUI, I have the outcome of 7 bands under the name Btoar1, Btoar2 etc.
Also trying to check the results via r-info for all bands I realized that bands have different values and also 0 values. For example for Band1:
Type of Map:  raster               Number of Categories: 0
 |   Data Type:    DCELL
 |   Data Units:   W/(m^2 sr um)        Vertical datum: (none)
 |   Rows:         2434
 |   Columns:      2251
 |   Total Cells:  5478934
 |        Projection: Transverse Mercator
 |            N: 4532411.19817413    S: 4459391.19817413   Res:    30
 |            E: 441929.01667078    W: 374399.01667078   Res:    30
 |   Range of data:    min = 39.0688188976378  max = 193
 |   Data Description:
 |    generated by i.landsat.toar
 |   Comments:
 |     Radiance of Landsat-5 TM (method uncorrected)
 |     Acquisition date (and time) ........... 2007-06-24 (-0.0000 h)
 |     Production date ....................... 2014-05-09
 |     Earth-sun distance (d) ................ 0.0000000
 |     Sun elevation (and azimuth) ........... -0.00000 (0.00000)
 |     Digital number (DN) range ............. 0 to 0
 |     Calibration constants (Lmin to Lmax) .. +0.00000 to +0.00000
 |     DN to Radiance (gain and bias) ........ -0.00000 and +0.00000
 |     Mean solar irradiance (ESUN) .......... -0.000
 |     Radiance to Reflectance (divide by) ... -0.00000
 |    i.landsat.toar -r input="B" output="Btoar" metfile="C:\Users\User\Desktop\thessaloniki\2007tm\thessaloniki2007tm\LT51840322007175MOR00_M\
 |    TL.txt" sensor="tm5" method="uncorrected" percent=0.01 pixel=1000 rayleigh=0.0 scale=1.0
Also for band2: min: 27.571968503937 max: 365
               band3: min: 13.4456692913386 max: 264
               band4:min:  -0.633976377952756 max:221
               band5:min: 0.231771653543307 max: 30.2
               band6:min: 8.87961417322835 max: 12.3681771653543
               band7:min: -0.15 max: 16.5
What I can do???
Thank you
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150508/d73b1dfb/attachment-0001.html>
