[GRASS-user] i.landsat.toar and zero values in GRASS 7.0.0
Nikos Alexandris
nik at nikosalexandris.net
Fri May 8 10:46:01 PDT 2015
Katerina-Karolina Karapanou:
> I have a Landsat TM image (2007) and I work in GRASS 7.0.0. in Windows
> 7. Once again, trying to apply the module i.landsat.toar in the right
> way, via GUI, I have the outcome of 7 bands under the name Btoar1,
> Btoar2 etc.
> Also trying to check the results via r-info for all bands I realized
> that bands have different values and also 0 values.
It would be suspicious, and most likely an error, if all bands have had
the _same_ values. And, zero values are also normally there. Check what
the zero pixels actually are (maybe create a new raster map with
r.mapcalc for all zero pixel values). Are they just a few, in- or
near-water, for example? Too dark surfaces?
> For example for Band1:
> | Range of data: min = 39.0688188976378 max = 193
> | Data Description:
> | generated by i.landsat.toar
> | Comments:
> | Radiance of Landsat-5 TM (method uncorrected)
> | Acquisition date (and time) ........... 2007-06-24 (-0.0000 h)
> | Production date ....................... 2014-05-09
> | Earth-sun distance (d) ................ 0.0000000
> | Sun elevation (and azimuth) ........... -0.00000 (0.00000)
> | Digital number (DN) range ............. 0 to 0
> | Calibration constants (Lmin to Lmax) .. +0.00000 to +0.00000
> | DN to Radiance (gain and bias) ........ -0.00000 and +0.00000
> | Mean solar irradiance (ESUN) .......... -0.000
> | Radiance to Reflectance (divide by) ... -0.00000
> | i.landsat.toar -r input="B" output="Btoar" metfile="C:\Users\User\Desktop\thessaloniki\2007tm\thessaloniki2007tm\LT51840322007175MOR00_M\
> | TL.txt" sensor="tm5" method="uncorrected" percent=0.01 pixel=1000 rayleigh=0.0 scale=1.0
The all zero values for band #1 may, inded, worth re-checking your
processing. But the rest, below, looks ok to me. It's not unusual to
have a few "erroneous" negative values. Check how many. I guess just a
few. There are various reasons why this can happen (search in the
literature).
> Also for band2: min: 27.571968503937 max: 365
> band3: min: 13.4456692913386 max: 264
> band4:min: -0.633976377952756 max:221
> band5:min: 0.231771653543307 max: 30.2
> band6:min: 8.87961417322835 max: 12.3681771653543
> band7:min: -0.15 max: 16.5
> What I can do???
Remember, these are Radianve valuse, not Reflectances. So, they seem
quite normal. Maybe you can set the begative pixels to zero. This will
not harm, I think, your processing chain.
Nikos
