[GRASS-user] run_gmfontcap.bat
Marvin Eng knot.tyer at gmail.com
Mon May 11 14:16:29 PDT 2015
The problem was exactly like you said.
running g.mkfontcap -o within a GRASS session fixed it.
thanks
marvin
On Sun, May 10, 2015 at 2:36 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Sun, May 10, 2015 at 11:45 AM, Marvin Eng <knot.tyer at gmail.com> wrote:
>> When installing GRASS GIS 7.0.0 in windows 8.1 I get a message from
>> windows saying "GRASS 7 has stopped working. A problem caused the program
>> to stop working correctly.
>> The GRASS installation window indicates that \etc\run_gmfontcap.bat is
>> being run and the command window indicates that it is "generating a font
>> configuration file by scanning various directories for fonts"
>> When I use the windows message to "close program" the installation
>> finishes without further issues and GRASS opens.
>> I am new to GRASS - Can you help:
>> Can I fix this during installation?
>> Should I try to run g.mkfontcap within in GRASS (if so how)?
>> I don't if fix this what problems will it cause me problems in the future?
> Hi,
> I wonder if this is related to this ticket:
> http://trac.osgeo.org/grass/ticket/2448
> You can try for example displaying legend - it might not display any
> numbers. In that case, try to run:
> g.mkfontcap -o
> in a GRASS session and afterwards try to rerender legend to see if it
> helped.
> Cheers,
> Anna
>> Marvin Eng
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150511/6086a21b/attachment.html>
