[GRASS-user] run_gmfontcap.bat
Anna Petrášová
kratochanna at gmail.com
Sun May 10 14:36:57 PDT 2015
On Sun, May 10, 2015 at 11:45 AM, Marvin Eng <knot.tyer at gmail.com> wrote:
> When installing GRASS GIS 7.0.0 in windows 8.1 I get a message from
> windows saying "GRASS 7 has stopped working. A problem caused the program
> to stop working correctly.
> The GRASS installation window indicates that \etc\run_gmfontcap.bat is
> being run and the command window indicates that it is "generating a font
> configuration file by scanning various directories for fonts"
> When I use the windows message to "close program" the installation
> finishes without further issues and GRASS opens.
> I am new to GRASS - Can you help:
> Can I fix this during installation?
> Should I try to run g.mkfontcap within in GRASS (if so how)?
> I don't if fix this what problems will it cause me problems in the future?
I wonder if this is related to this ticket:
http://trac.osgeo.org/grass/ticket/2448
You can try for example displaying legend - it might not display any
numbers. In that case, try to run:
g.mkfontcap -o
in a GRASS session and afterwards try to rerender legend to see if it
helped.
Cheers,
Anna
> Marvin Eng
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150510/bc0d4dcb/attachment.html>
